Originally Posted By DAYCLONA
Your only choice
TJ out of the equation???
I put a lot of Ted Janek parts on my clone. But this one I want to keep steel. If I could replace the bottom center it would be a nice nose. I think I got a hook on a bottom center section. Thanks folks....
TJ, as in Tedrick Janek?, if so Ted's nose is fiberglass, not steel, I'll assume the OP wants a "factory" style steel replacement nose or panels to repair his existing nosecone...hence Gene Gregory
