Cool little truck!
1998 Dodge Dakota Sport
(Factory 5.2L/5 Speed combo)
Powertrain
6.4L 392 Hemi
Tremec T-56 Viper 6 speed
McLeod aluminum flywheel and clutch
9.25” LSD with 3.92 gears
Electronics
Mopar 392 Crate engine management kit
AutoMeter Cobalt electronic gauges retrofitted into a CNC plate in the cluster
Tach/Fuel Level/Water Temp/Oil Pressure/Voltage
Battery relocated to the bed – Moroso box, shut off switch hidden behind license plate
HHR cooling fan fitted onto stock radiator
Full power accessories and radio
Exhaust
Custom ceramic coated long tube headers – 2” primaries to 3.5” collectors
3” dual exhaust with straight through mufflers, dumped up and over the rear axle
Suspension/Brakes/Mounts
PowerStop drilled/slotted rotors and pads
New brake calipers
Stock drums in the rear
Ground Force lowering springs in the front, 2” block in back
Calvert Racing Caltracs adjustable traction bars
Schumacher Creative Engineering engine mounts and oil pan
Fuel System
Walbro 255 pump in stock basket
6AN black braided nylon feed and return lines with in line filter
Aeromotive A1000 adjustable fuel pressure regulator
