I have been considering re-wiring my Savoy with an updated universal system with fresh wires. Like a lot of our cars the wires and connectors are getting very brittle and and are really not up to the job with added accessories and higher output alternators. I was considering just adding a 5 circuit sub system for my added components or should I just change over the entire system with fresh wires to all components. I have an MSD ignition so that system is very basic and I also have upgraded to a Denso internal regulator alt. so that should also make easier. I just need a basic system to run the lights,wipers,fuel pump,and horn.
Thanks in advance
Gus
