Originally Posted By R/T1968R/T
I think with out any quench Im screwed. I can always put them on a smog motor or a motor with L2266 which are .090 in the hole.
How deep are the open part of the chambers now? You can get a piston made that will give you quench and a streetable compression, I had Diamond make me some a few years ago.
Sorry for the crappy picture, it's a D shaped dome with a D shaped dish, 9.5 compression 440 , though your heads being as small as there are might be a challenge on the dish size ?
running up my post count some more .
