It would require a conversation before I would recommend any other cam, but I think getting rid of some seat timing would be a step in the right direction.
You said "pv's"....... If you're still running one in the secondary side, remove it and replace with a plug....... And jet up accordingly(around 8 sizes).
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
