Originally Posted By cbusters
I had a new factory windage tray/seal with the new Milodon pan and all the bolts were tight from the machine shop. There was just the assembly oil in the pan and as we were rotating the engine on the stand to clean it for painting, the oil was weeping out of the sides and front of the pan seal. It had sealant on it.
It takes a good bead on one edge to button it up, it is still a better setup than a cork gasket. 1,500 miles on mine so far, not a drip.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
