I don't like the idea of forming, making and welding the frame up with flat stock What say you guys more knowing about doing this?
biggest concern doing it this way is to NOT grind the weld away radiusing the corners to make it appear super smooth. if the weld bead is not compromised by grinding it away, it will be as strong as if it was a one piece chunk. takes some practice to get right, however. hope this makes some sense.
