Would someone have the inside dimensions of a reproduction battery
topper for a size 24 battery. Also, what is the measurement from center
to center on the holes for the battery posts? Thanks. George.
May find some info here: http://a12mopar.com/yabb/YaBB.pl?num=1452758076;start=all (actually see the link below, this one didn't work sorry)
If you need the dimensions for help in finding a battery that a topper will fit in the above link I found one at Tractor Supply after lots and lots of searching.
MikeR
A12 Registry link to battery topper info click here ANOTHER LINK TO BATTERY TOPPER AND CAPS
