I am relocating the COP coils and have the original boots and braided cables pulled off the coils and now working on the coil mounts. Does anyone have any experience adding plug wires to these? I need an idea about the clearance that is needed above the towers on the coils. How much room do I need to allow after the boot and wire is installed on the coil before the wire can start bending to clear parts? I am assuming the wires will have straight boots but have no idea what they will look like and can't order them until I have the coils mounted and get the lengths figured. A picture would be great also. Thanks!
