Originally Posted By cagebob1
Started making some shake down runs last weekend. Leaving off idle, short shifting, resulted in a 1.41 60ft and a 6.29 @ 110 to half track. On the scales at Wildhorse Pass it weighed 2220 lbs. I'm happy ...seems like a good place to start. boogie
I never set the world on fire my first time out but if you get that to run about the same as mine, you should probably be mid 5s at that weight
Gen 3 power 6.22@110, 9.85@135
Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
