what is the crankshaft stroke and cyl bore? is it the conventional 392" specs.? will a stock 392 bottom end do the job or do you have to upgrade. i assume pistons and rings are something special at least?
is this a non mds cam or did you modify it for your cam? i have a 2012 5.7 from a 2500 truck with 80k miles. i understand its not an mds cam. do you know if this block is different for the non MDS cam? i grabbed it because its not mds. do you have an opinion?
sorry ive did not see the build specs or build post on this motor. but it looks simple and reliable..and for that kind of power.. its got me motivated .. thats plenty for my needs. jim
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
