Originally Posted By 64hemi330sedan
I need to put some on my car. I am looking for a clean,easy and light weight method to do it.
Unless its light on the nose with an aluminum block it'll need the travel. Mine is 54.5% (mega block, steel frt end) on the nose with 113" wb. I'm ready to give it even more. You can tighten the front rebound for a better method of control. Poor track conditions with good power will need the travel.
Doug
