I just fixed a similar problem with my 2005. The rear drivers door lock stopped working. I thought it was the actuator, but it wasn't. Two of the wires in the boot between the door and the jam were broken. The wires can be accessed by unplugging the harness on the truck side of the jam. A small screw driver will release the catch on each side of the plug. Then slip the boot back and inspect the wires.
