I made some press in taper sleeves to use the speedway pinto heim studs. Im mounting the Heims on the bottom. If I get some bump steer I will mount them on the top. I need to tighten things up, Do the bump stops and get a Alignment. The crossmember might be to close to the ground, I may have to raise it a hair. But no more Camber or tie rod angle problems.
