The Hemi 6 will not work on a 6.4L due to the tone wheel. To use the Hemi 6 you would need to change the tone wheel to a 6.1L wheel or according to FAST their XIM can be used in a stand alone carb application and can be setup to use the 6.4L fine tooth wheel. You will still need to lock the phaser in the timing chain.
Stock Displacement, pump gas, 5.7L Gen 3 Hemi, early 5.7L heads, 3670lbs with driver, Best time and MPH 11.11@120.9MPH
