I'm having a hard time starting my new car. the msd has a ten to fifteen second delay before it starts to flash the led when cranking the engine with the ignition on. the car has a crank trigger not a distributor. I also did the msd tap test. I does put spark but with a ten to fifteen second delay. I think my 7al-2 is jacked. whiney
