Now that it’s warming up a bit I’m back on the 37 again. The Mustang II front end was already installed when I bought the 37. The previous owner had used a burned up Mustang II as a donor and transferred the suspension components….. worn out ball joints, bushings, calipers, springs and all to the truck.
I kept putting off rebuilding the front suspension using the excuse that I wanted the full weight (engine, transmission etc ) on the front end so I could get the correct front springs in it. Anyway I’ve run out of excuses so it’s time to rebuild the suspension. Rebuilding control arms is not my favorite job by any stretch of the imagination but being basically cheap and having the time and tools I ordered bushings and ball joints rather than a new set of control arms.
My luck held true to form. One of the upper control turned out to be bent. Of course I didn’t pick up on that until after I had spent an hour knocking the ball joint and bushings out of it.
I had another set of used control arms so other than wasting time on the junk one I'm not out anything and the arms are ready to go back on.
Today will probably be spent getting the holes cut in the upper spring pockets so I can get the ride height adjusters installed.
Once that’s all done I’ll be able to get it back together and do the brake conversion. I’m going from the 9” rotors to 11” which should finish up what I need to do on the front suspension.
