Here we go again, getting set to install fuel injection. Installing it all so that it can be undone/returned to stock in an afternoon.....OEM tank is still clean but vents were plugged. I will save it for restoration. I'm currently cleaning any NM dirt or light surface rust from the rear frames in and will coat/protect before installing the tank. Note the rements of the tank pad on the original tank are not original
