Quote: 64 dodge quater panels are differnet shape . The shape is rounded around wheel opening lip plymouth and it is flat on a dodge . 63-65 plymouth will work.
Now that you point it out, it's quite obvious... so need to whip out plan B Do you know if the overall opening shape is still the same? The outer fender well piece being the same?
