on the diffusers, the rear of the rocker panel, would you want to have the tail end angle outwards to the tire sidewall, instead of ending the way you have it mocked.. Also, the rear of the 1/4 drop, would you want to taper that towards the center of the car? I'm not totally sure of the top speed concept, just throwing that out there. Would doing this make the car more apt to be "squirrely" at top speeds? And, what do you plan to do for cooling those ginormous brakes?
When you decide to quit, THAT is the moment when you would've succeeded..
