wow! ODD RUST up that high... i think there's more rust hiding on the car than can be seen.. i bet mine and larry's are much closer condition wise than meets the eye.. mine just has its clothes off! hahahahha.. dan
That rust is from the belt moulding clips. there should be moulding there
Larry
ok that makes sense then i had never seen rust like that.. cool good luck dan
